Features:
2618 Alloy - The strongest Alloy available with the best strenght at high temperature and low silicone content, for low porosity
Heavy Radii - Creating a large smooth radii from the skirts and pin boss into the crown prevents flex and cracking.
GarageGT spec 1400HD Pistons:
Bore: 85.5mm / 3.366"
Stroke: 88mm / 3.465"
Compression Ratio: 9.0:1 (with 0.86mm/0.034" headgasket)
9310 Pins - 0.225" wall thickness minimizes flex
Piston Brushing - Soft radius resulting in improved air flow and flame travel, more prone to detonation and pre-ignition
Ceramic Barrier - Reflecting heat back into the combustion chamber makes power and protects piston
Skirt Coating - Reduces friction and provides much better wear characteristics
XX Rings - State-of-the-art steel rings, nitrided for excellent wear and break-in, Napier 2nd ring for superior oil control and superior dimensional quality.
Les plus costaux de la marque, j'ai préféré pour le stroker (jupe plus courte)
